Analog and audio
Forum board changes
alarm and sound
Hello.I would like to do the following but since I don't have the necessary skills I ask you. If possible, I prefer to control everything with the keys.I make a list of the functions that I would like to implement:ALARM SECTION- wake up in the mornin...
arivel1 by Associate II
  • 3232 Views
I am using Steval-mksbox1v1. I need a sample code or standard library , application notes and programming manual for Microphone TS922EIJT and MP23ABS1TR
How to configure ADC in STEVAL - MKSBOX1v1 (With DMA or W/o DMA)How are the setting to be used for this board. (Clock dividing by ?) - For Audio it will be single channel continuous scanThere are two pins in STEVAL - MKSBOX1V1 MREF and M1P what shoul...
