Analog and audio
Forum board changes
I have been testing with TDA7294 and need to switch to TDA7293. My test board works fine with the TDA7294 but when I put in a TDA7293 with no load and apply power to the device it draws massive amount of current. Can you tell me what i am doing wrong.
I need to run the TDA7293 because i wont to run 50 volts rails. I am so confused , i thought the parts were pin compatible. I have read the data sheet a few times and don't quite understand what is wrong. I am basically using the schematic of the...
SClif.1 by Associate II
  • 3542 Views
What is the range of frequency that 1N5711 diode can operate at my element? OR What is the range of Reverse Recovery Time of 1N5711 diode at my element? (Trr) OR What is the cutoff frequency at my element?
Hello. My name is Dae Hun Hwang from Korea.​I am making Lectenna. (LED + Rectify + Antenna)​I attached my circuit and picture.​Length of my element is about 6cm.​I used normal LED and 1N5711.​I am experimenting at 2.4GHz.​Thank you.​
DHwan.5 by Associate
  • 3160 Views
cross reference
part # 09395699 delco ic. can you give me your part # It is a st part.
lhuet.1 by Associate
  • 8059 Views
