2023-09-25 12:46 PM
I am using the STM32CubeProgrammer with my board in DFU mode (over USB).
It programs fine, but my application does not run after programming even though I checking the "Run after programming" option. and by programs fine, I mean if I power fail the board, the code runs.
Any suggestions on troubleshooting this?
Thanks,
Mark
2023-09-25 12:55 PM
Hello @MButsch
I suggest you to take a look to this video, this post and this application note.
Best regards.
II
Best regards.
II
2023-09-26 5:29 AM
Thank you for the suggestions.
I am able to update the firmware using STM32CubeProgrammer, it just does not start running my application after the update is complete, despite having checked the "Run after programming" option.
