2025-10-13 10:20 PM
The App launches and immediately quits.
App version 2.19 despite downloading 2.20 package.
Any ideas?
thanks!
./STM32CubeProgrammer
?J2??
chdir /Applications/STMicroelectronics/STM32Cube/STM32CubeProgrammer/STM32CubeProgrammer.app/Contents/MacOs/bin/.
current dir /Applications/STMicroelectronics/STM32Cube/STM32CubeProgrammer/STM32CubeProgrammer.app/Contents/MacOs/bin
Loading PRG Library: /Applications/STMicroelectronics/STM32Cube/STM32CubeProgrammer/STM32CubeProgrammer.app/Contents/MacOs/bin/libCubeProgrammer_API.dylib
TrackedData.json file does not exist !
99 external Loader list
2025-10-15 7:08 AM
Hello @Jiiijo,
Are you seeing this after an update or is it specific to v2.19 or v2.20 standalone versions ?
Aziz
2025-10-15 2:37 PM
Thanks Aziz,
This is a standalone new install, not an update from a previous version. (I did try version 2.18, 2.19, in each case I deleted the "STMicroelectronics" directory from Applications).
So, I would then say it is specific v2.19. Please note that the 2.20 Setup installs the 2.19 version of the app. (see screen grab - SetupSTM32CubeProgrammer-2.20.0.app & STM32CubeProgrammer.app 2.19.0 infos).
Also STM32TrustedPackageCreator.app runs without issue.
I hope that answers your question.
thanks again
J
2025-10-16 1:48 AM - edited 2025-10-16 1:49 AM
Hello @Jiiijo
What your screenshot shows is the two versions (v2.19 and v2.20). Nothing more.
"Please note that the 2.20 Setup installs the 2.19 version of the app"
=> I highly doubt this; I think this is an issue of unproper uninstall of the app. What I recommend is to uninstall all instances of CubeProgrammer and re-install the latest v2.20.
Aziz
2025-10-17 2:55 AM
Thanks Aziz,
I have;
- uninstalled the app,
- downloaded the latest version by clicking "get latest",
- unpacked "stm32cubeprg-mac-v2-20-0.zip" to "SetupSTM32CubeProgrammer-2.20.0.app",
- run the Setup app
App still launches and quits immediately.
The info.plist shows CFBundleVersion 2.4.0 and getting info app (info.plist) shows Version 2.19.0 still. This is all within "get package contents" of STM32CubeProgrammer.app - so it was installed fresh from the SetupSTM32CubeProgrammer-2.20.0 - I do realise this is not much help.
I'm new to this, so please excuse my ignorance - Is there any other information I can provide that might help resolve this issue?
I have included the content below when launching the app from Terminal (Mac CLI) after the - TrackedData.json file does not exist ! this might mean something to you?
thanks again,
J
Exception in Application start method
Exception in thread "JavaFX Application Thread" java.lang.NullPointerException
at com.sun.javafx.font.MacFontFinder.populateFontFileNameMap(MacFontFinder.java:89)
at com.sun.javafx.font.PrismFontFactory.getFullNameToFileMap(PrismFontFactory.java:1705)
at com.sun.javafx.font.PrismFontFactory.getFontResource(PrismFontFactory.java:438)
at com.sun.javafx.font.LogicalFont.getSlot0Resource(LogicalFont.java:194)
at com.sun.javafx.font.LogicalFont.getDefaultAAMode(LogicalFont.java:409)
at com.sun.javafx.font.LogicalFont.getStrike(LogicalFont.java:413)
at com.sun.javafx.font.PrismFont.getStrike(PrismFont.java:73)
at com.sun.javafx.text.PrismTextLayout.setContent(PrismTextLayout.java:138)
at javafx.scene.text.Text.getTextLayout(Text.java:229)
at javafx.scene.text.Text.needsFullTextLayout(Text.java:184)
at javafx.scene.text.Text.access$200(Text.java:95)
at javafx.scene.text.Text$2.invalidated(Text.java:389)
at javafx.beans.property.StringPropertyBase.markInvalid(StringPropertyBase.java:109)
at javafx.beans.property.StringPropertyBase.set(StringPropertyBase.java:144)
at javafx.beans.property.StringPropertyBase.set(StringPropertyBase.java:49)
at javafx.scene.text.Text.setText(Text.java:370)
at javafx.scene.text.Text.<init>(Text.java:129)
at com.st.controllers.MainWindowController$1.run(MainWindowController.java:476)
at com.sun.javafx.application.PlatformImpl.lambda$null$5(PlatformImpl.java:295)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$6(PlatformImpl.java:294)
at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:95)
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:382)
at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:321)
at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:893)
Caused by: java.lang.RuntimeException: Exception in Application start method
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:823)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$1(LauncherImpl.java:181)
at java.lang.Thread.run(Thread.java:750)
Caused by: java.lang.NullPointerException
at com.sun.javafx.font.PrismFontFactory.createFont(PrismFontFactory.java:536)
at com.sun.javafx.font.PrismFontLoader.font(PrismFontLoader.java:182)
at javafx.scene.text.Font.font(Font.java:148)
at javafx.scene.CssStyleHelper.deriveFont(CssStyleHelper.java:1804)
at javafx.scene.CssStyleHelper.lookupFont(CssStyleHelper.java:2115)
at javafx.scene.CssStyleHelper.lookup(CssStyleHelper.java:1057)
at javafx.scene.CssStyleHelper.transitionToState(CssStyleHelper.java:839)
at javafx.scene.Node.impl_processCSS(Node.java:9202)
at javafx.scene.Parent.impl_processCSS(Parent.java:1249)
at javafx.scene.control.Control.impl_processCSS(Control.java:868)
at javafx.scene.Parent.impl_processCSS(Parent.java:1280)
at javafx.scene.Node.processCSS(Node.java:9069)
at javafx.scene.Scene.doCSSPass(Scene.java:545)
at javafx.scene.Scene.preferredSize(Scene.java:1646)
at javafx.scene.Scene.impl_preferredSize(Scene.java:1723)
at javafx.stage.Window$9.invalidated(Window.java:889)
at javafx.beans.property.BooleanPropertyBase.markInvalid(BooleanPropertyBase.java:109)
at javafx.beans.property.BooleanPropertyBase.set(BooleanPropertyBase.java:144)
at javafx.stage.Window.setShowing(Window.java:965)
at javafx.stage.Window.show(Window.java:980)
at javafx.stage.Stage.show(Stage.java:263)
at com.st.app.Main.openCubeProgrammmerWindow(Main.java:574)
at com.st.app.Main.start(Main.java:165)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$8(LauncherImpl.java:769)
at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$7(PlatformImpl.java:326)
Exception running application com.st.app.Main
2025-11-20 10:50 AM
I get the exact same Java runtime error when trying to run STM32CubeProgrammer version 2.21.0 on my M1 Mac running Tahoe 26.1 and Java 1.8.0_331. Does anyone know a workaround for this?
