2023-04-08 5:18 AM - last edited on 2025-07-17 7:59 AM by Andrew Neil
am trying to connect stlink v2 debugger with stm32f413 mcu hardware in Cube programming sotware
am getting Error: Cannot connect to access port 0 If you are trying to connet to a device with TrustZone enabled please try to connect with HotPlug mode
2023-04-08 5:48 AM
Not much information to work with here.
Suggests the chip/board aren't running.
Start by providing information about the board, how the debugger is attached, and how everything is powered
2023-04-09 11:17 PM
what is HotPlug mode do u have any idea
2023-04-13 8:55 AM
Hello @saraiahd,
Welcome to ST Community !
Hot Plug mode is used to connect to the target without a halt or reset. You can check STM32CubeProgrammer user manual for further details on the connection modes.
For your specific case, as stated by @Community member, could you provide more info on how you're connecting your debugger to the target ?
Thanks,
Aziz
