2022-10-04 6:52 AM
Hello everyone,
I have the following failure.
"CubeProgrammer_API or one of its depndencies missing. Please try reinstalling the program or check your java architecture."
But on my windows 10 system is "Microsoft OpenJDK 11.0.16.101 in 64 Bit" already installed.
Does anyone have a tip or an idea what to do to make the program work?
2022-10-04 7:00 AM
Hi @MScha.10 ,
Can you please tell how do you launch CubeProgrammer, using command line or GUI?
Did you install it using admin rights? Try to install it and run it as admin.
Houda
2022-10-04 9:34 PM
Hi Houda,
Thank you, for your answer. I tried to launch CubeProgrammer with the GUI.
I installed it with admin rights and also tried to run with admin rights.
Max
2022-10-11 1:57 AM
Hi @MScha.10 ,
Sorry for the delay.
It seems to be a java issue (FYI no need to install any Java on your machine since 2.6.0) , I suggest you use these steps :
Please test and tell me if it is OK.
Houda
