2020-03-23 2:28 PM
Hi, I can't fix why cubemx is stucking while copying files for code generation. I'm using Win 10 (64bit) and Java_Runtime_Environment_(64bit)_v8_Update_45. Can someone please help understand how to fix it ?
2020-04-03 2:36 AM
Imen DAHMEN, hello,
thank you very much for your help. I have already been able to solve the problem. I had a specific character « # » in the path of my project folder.
2020-03-24 1:10 AM
Which STM32CubeMx version are you using ? If possible provide your ioc file for check, this will help our CubeMx team to answer you.
Best Regards,
Imen
2020-03-24 1:38 AM
2020-03-31 9:47 AM
Hello @CChuk.1 ,
I tested your attached ioc file using STM32CubeMX v5.6.0 and STM32CubeF1 V1.8.0 in Win10 and I generated successfully the project.
Try again, otherwhise uninstall STM32CubeMx, then reinstall it.
Best Regards,
Imen
2020-04-03 2:06 AM
Can you please attach the "STM32CubeMX.log" file.
2020-04-03 2:36 AM
Imen DAHMEN, hello,
