2021-05-17 4:40 PM
I created a new project for an STM32F407VE and when the code is generated CubeMX puts this in SystemClock_Config:
/** Activate the Over-Drive mode
if (HAL_PWREx_EnableOverDrive() != HAL_OK)
Error_Handler();
When you try to compile it, it gets an error because HAL_PWREx_EnableOverDrive() is not defined!
The whole SystemClock_Config is here:
void SystemClock_Config(void)
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.PLL.PLLM = 25;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
Error_Handler();
Error_Handler();
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
Error_Handler();
Mike.
2021-05-17 4:53 PM
Overdrive mode is required for speeds above 168 MHz. It's not overclocking. In any case, it's not available on the F407 so generated code shouldn't have it.
I couldn't reproduce this on a new project. Attach your IOC if you can.
Here's what CubeMX spat out for me:
* @retval None
Error_Handler();
Error_Handler();
2021-05-17 4:53 PM
* @retval None
Error_Handler();
Error_Handler();
2021-05-17 4:58 PM
