Why does Stm32CubeMX not work.
FVosm.1
Associate
The CPU is STM32L071KZ. I can select it in two packages. I pick it, assign pins, select a folder to store, select STM32Cube as IDE. It creates the code (ther eeven is an SRC and INC folder, but no .project. STM32Cube refuses to open it.
I try TrueSTUDIO as an IDE. It succeeds, but STM32Cube has to convert it. A new pop up, FInish is grayed out.
I continue from MX. Open STM32Cube from three. Behold, I get a project file and no conversion needed.
I'd like to make a second copy in another folder. I cannot change the folder name.
I spend 3 hours creating a .h file. Rerun MX. Create code, .h file lost.
Recreate .h file. Compile. Cannot find main.h (I can, it is in the INC file). It need "stm32l0xx.h" Neither the compiler nor I can find it.
It needs stm32l0xx_ll_dma.h (I do not use it, I did nto enable it in MX). Compiler cannot find it. I can, it is in the Driver\Inc folder.
I download the latest STM32CubeMX version 2.6.1. Nothing changed.
Can anybody tell me what I ma doing wrong?
Thanks.
-- Frits
1 REPLY 1
Hello @FVosm.1​
Could you please share your ioc file.
Best regards,
Nesrine
