STM32H745 RMII and DP83822 Question
WTieg.1
Associate II
I use STM32H745 RMII and DP83822
To use CubeMx generate code for lwip, selected phy is LAN8742.
Modify the code
But can't make it work
Any body has the experience or some advice ?
Hope someone can help me.
11 REPLIES 11
WTieg.1
Associate II
Now I make DP83822 works. LED_0 is lighten
But the network can't work
alister
Lead
After you've resolved your PHY problem, check out my bug-fixes and improvements to ST's STM32H7 ETH driver and lwIP ethernetif.c at https://community.st.com/s/question/0D50X0000C6eNNSSQ2/bug-fixes-stm32h7-ethernet
WTieg.1
Associate II
Hi Alister
Thanks for your answer.
I read the link, I find that ​v1.5.0 & v1.6.0 has the problem .
I use v1.7.0, this version still has the problem
Just replace the file is ok ?
Read the posts there carefully. Porting it to your software is technical and requires skill and care. If you use it, to assist other developers, please post a summary there confirming it's ok and/or any problems with it you'd had to solve. Thanks.
HVict
Associate II
Hi WTieg.1
Have you succeeded in modifying the code to interface with the DP83822?
WTieg.1
Associate II
To Hvict
I solved the problem
But I don't know how to  submit my bug-fixes and improvements
Add "Bug-report" to your topic list, attach the fix, CC @Amel NASRI​, and search community for any updated "how-to" instructions.
IMor.1
Associate II
Hi @WTieg.1​
I am going to use the same STM32H745 RMII and DP83822, Do you have an updated code ?
MSile.1
Associate II
I'm facing the same problem: STM32H7 + DP83822...any updated code??
