2026-02-16 2:10 AM
this is a small but annoying little bug: Sometimes after running code generation, apparently the STM32CubeMX application keeps some files open in the "cmake" subdirectory. This then prevents me from modifying or deleting (to force re-generation on the next code generation run) the files. It also interferes with my Post Generation user script which modifies those files.
This can be seen e.g. via ProcessExplorer:
It would be helpful if STM32CubeMX would close all file handles after code generation, ideally before calling the post generation user scripts.
Thanks!
2026-02-16 5:29 AM
Hello @Erlkoenig
Your change request has been forwarded to dev team under internal ticket ID 227258 for further investigation and feasibility check .
I will keep you posted with updates.
THX
Ghofrane
2026-02-16 2:14 AM
Hello @Erlkoenig
I'm currently investigating this behaviour.I will get back to you ASAP.
THX
Ghofrane
2026-02-16 5:29 AM
Hello @Erlkoenig
THX
Ghofrane
2026-02-16 6:57 AM
Thank you very much!
