2022-09-13 5:27 AM
Tying to use STM32CubeMX 6.6.1 on an M1 Macbook Pro but when I try to save a new Project I can navigate to the Documents folder but no files or folders are shown. STM32CubeMX will duly create a new folder but if you then try and open it by you can't because the File Open fails to show files and folders in Documents.
If you try and open a .ioc file within a subfolder of Documents STM32CubeMX opens but fails to load the file, you just end up on the opening screen where you select your starting position.
Is it only me with this problem as for me this makes using a Mac just now impossible.
Thanks
EDIT: Just found out if I run using sudo from a Terminal I can see all the expected files/folders.
2022-09-13 5:43 AM
Hi @Peter Allnutt ,
Can you please follow this solution:
STM32CubeMX 6.4.0 doesn't interact nicely with MacOS 12.1 (Monterey)
Let us know your feedback.
Regards,
Aymen.
2022-09-13 5:43 AM
Hi @Peter Allnutt ,
Regards,
Aymen.
2022-09-13 7:06 AM
Brilliant, failed to find that when I searched earlier. All up and running now, thanks.
