2022-07-24 7:20 AM
The attached simple project contains an ioc-files where the DFSDM peripheral is configured: channel 0 and channel 1; filter 0 for channel 0 and filter 1 for channel 1. In addition i have configured TIM6; but that's not relevant for the issue. This all is based on a real project; but i have narrowed it down to a minimum because only the code generation process is relevant.
The issues are in generated file dfsdm.c in sub folder Src. After generation, the file contains two errors:
Please fix.
Regards ... Matthias.
2022-08-10 5:34 AM
Hello @MJord ,
Thanks for your feedback,
Issue confirmed and raised to the dev team to fix it. I will keep you posted with updates.
Internal ticket number: 132956 (This is an internal tracking number and is not accessible or usable by customers).
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
2022-08-10 5:34 AM
Hello @MJord ,
Sara.
