2021-05-27 3:12 AM
it is similar to https://community.st.com/s/question/0D53W00000bfw14SAA/hrtim1-interrupt-request-source-does-not-produce-the-correct-code-for-hrtime
the generated code is
pTimerCfg.InterruptRequests = HRTIM_MASTER_IT_NONE;Here is the IOC file.
2021-05-31 7:14 AM
Hello @victagayun
Your post is related to CubeMx generation and our team is aware of this issue, and working to resolve this.
Hello @Khouloud ZEMMELI ,
Can you please check the status of this issue and share the update about the taken action?
Thanks
Imen
2021-05-31 7:19 AM
Hi @Imen DAHMEN , thanks for the mention, I'll take it in charge.
Thank you @victagayun for raising the problem, I'll check your ioc file then I'll get back to you.
Khouloud
2021-05-31 7:30 AM
Hi again @victagayun
Issue is under analysis and still not fixed, we will do our best to fix it soon.
We are deeply sorry for any inconvenience that may have caused..
Thanks for your contribution,
Khouloud
