2020-10-06 3:59 PM
While Editing USER_LABEL on GPIO Configuration window facing the following issue
need to set common word for particular GPIO like
PC0 ----> USER1_KEY
PC1 ----> USER2_KEY
PC3 ----> USER3_KEY
PC4 ----> USER4_KEY
now i'm selecting all the GPIO in group selection then adding the USER_LABEL as _KEY
its working
then i'm trying to select the individual pins and adding the remaining label names like
_KEY to USER1_KEY,
in this situation what happens is after selecting the GPIO ping and at the bottom USER_LABEL editing text box, i'm placing the cursor at the start of "_KEY" then start to type USER1, but cursor automatically moves to end of text after single key pressing
i'm not able to complete the USER1_KEY since at every key type cursor automatically moves to end
but if i'm typing fresh then i can type whole word without any problem
Kindly correct this minor issue
2020-10-08 1:57 PM
Hello @Varadharajan V
Could you please share your .ioc file to check with.
Best regards,
Nesrine
2020-10-08 2:19 PM
Hello Nesrine
I'm attaching the .ioc file for your reference
on this file i already created the common word for input and output
also made one example for input and output like USER1_KEY, USER1_OUTPUT
now you can try to edit the other pins label using GPIO->Configuration Window->Select the particular Pin->on User Label section try to add the USER2,USER3,USER4 in front of already typed _KEY,_OUPTUT, you can see the effect
Thank You
Varadharajan V
2020-10-09 6:41 AM
It will be internally checked.
Best regards,
Nesrine
2020-10-09 6:47 AM
Thanks for the feedback, issue reported to the tool development team that will plan the correction .
Best regards,
Nesrine
2021-05-31 5:57 AM
The error as describe seems corrected (I face the same some time ago)
But editing the User Label is still really slow. It is like working on a CPU at 100% charge. The display is really slow
