2020-11-10 2:47 AM
I have a STM32CubeMX installed on an offline cumputer (that cannot be changed!)
I would like to install the last firmware for L0 familly, so I download:
From local, there is no problem to install the version 1.11.0. But when selecting the 1.11.3 file, there is an error "corrupted or not recognized package)
How can I install the 1.11.3 FW version?
I tried to extract the 1.11.3 zip in the repository directory. But after that, the version 1.11.3 do not appear in the Packages Manager, and version 1.11.0 is no more there!
Thank you for your help
Antoine
2020-11-10 2:59 AM
Hello @ANauz.1
Could you please Referesh the Manage Embedded SW packages ? if still there's a problem try to uncheck the use Default Firmware location then Browse and select the 1.11.3 FW version under Repository ?
Best Regards,
Khouloud
2020-11-10 2:59 AM
Hello @ANauz.1
Best Regards,
Khouloud
2020-11-10 5:30 AM
Yes it seems to work.
(Before that, I also copied the "user\.stm32cubemx\plugins\updater" directory from my online computer to the other. I do not know if it change anything)
Thank you
2020-11-10 5:34 AM
Great! you are always welcome.
Best Regards,
Khouloud
