2020-10-09 4:52 AM
I have started from the command line so I can see errors. It starts up ok but when I try to create a new project using "ACCESS TO MCU SELECTOR" it throws the error:
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: com.st.microxplorer.mcufinder.gui.selector.MultiSelectorDialog.<init>(Ljava/awt/Frame;Ljava/lang/String;Ljava/awt/Image;)V
at com.st.microxplorer.plugins.filemanager.engine.MainFileManager.userNewConfig(MainFileManager.java:118)
at com.st.microxplorer.plugins.filemanager.FileManagerView.getSpecificTask(FileManagerView.java:213)
at com.st.microxplorer.maingui.HomeNewTaskLinePanel.jButtonNewConfigurationMCUActionPerformed(HomeNewTaskLinePanel.java:117)
at com.st.microxplorer.maingui.HomeNewTaskLinePanel.actionPerformed(HomeNewTaskLinePanel.java:77)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
2020-10-10 8:24 PM
Hi Aymen,
Just a further updated. I have updated this PC to Mint 20, the most recent version. It includes the latest STM32CubeIDE in the standard Mint software sources so I installed that. It is all working ok now so no further action is need for support by me.
Thanks for the prompt attention to my original query.
2020-10-09 5:53 AM
Hi @David Annett ,
According to CubeMX User Manual UM1718, the supported system for Linux are RedHat, Ubuntu and Fedora.
But we will try to setup the Linux Mint OS to reproduce what you are seeing.
Can you give us the Linux Mint version used by you ?
Regards,
Aymen.
2020-10-09 3:15 PM
Hi Aymen,
It is Mint 18, which is based on Ubuntu 16.04 LTS.
2020-10-10 8:24 PM
Hi Aymen,
2020-10-11 11:37 PM
Hi @David Annett ,
Good news ! You are welcome.
Regards,
Aymen
