2022-01-04 11:50 PM
I am trying to add FreeRTOS support in an STM32CubeMX project, and import into Rowley CrossStudio.
In CubeMX, I have tried all toolchains, and then import them into CrossStudio.
But none of them works, and I get a ton of compiler errors.
When generating an STM32Cube IDE project (GCC/Eclipse), and import into CrossStudio, I get problems with newlib library, which are impossible to solve.
Has anyone experience with generating a CubeMX project with FreeRTOS enabled, and import into Rowley CrossStudio?
I have made projects without FreeRTOS support, and importing into CrossStudio works fine.
But when adding FreeRTOS, things gets messy...
Thanks !
Kaare
2022-01-11 4:17 AM
Hello @Kåre Kjeldsen ,
I couldn't reproduce the issue so I advise you to use one of CubeMX supported Toolchains (CubeIDE, EWARM, MDK ARM), it is more guaranteed.
Sara.
2022-03-07 11:30 PM
Hello @KKjel.1,
This issue is fixed in STM32CubeMX latest release.
V6.5.0 is now available under this Link.
When your issue is solved, please close this topic by choosing Select as Best.
Thanks for your contribution.
Sara.
