2016-12-06 12:19 PM
Cube slows down the point when it is pretty much very hard to use. Sometimes clock resolver ends up in an continous loop which leads nowhere. Also on chips with more pins like BGA packages Cube slows down noticeably. Not sure how it is on Windows or Linux as I only use OSX for development.
#stm32cubemx2016-12-07 12:20 AM
Hi
Hockuba.Krzyszto.002
,Could you please precise inwhich CUBEMX version you have found the issue. So, we can verify it.
-Nesrine-
Ifmy suggestanswers your question, please mark it as correct.Thank you
2016-12-07 2:54 AM
Same here on Windows 10, the clock view is very slow, and obviously is doing a lot of (useless) calculations as my laptop starts blowing air while on this page !
Can't remember which version I was running, but I updated to latest version (4.18.0) and still the same !
It used to work very good some months ago, now it is barely usable.
Need a fix ASAP.
Thomas.
2016-12-07 3:39 AM
Hi
ELMHIRI.Syrine
it's on the new version of CUBE 4.0.2016-12-07 3:42 AM
Hi
,I'll report this issue to our MXteam for checking.
Sorry for the inconvenience it may bring.
-Nesrine-
2016-12-07 4:02 AM
Hi
Legrand.Thomas
,The issue has been reported internally.
-Nesrine-Ifmy suggestanswers your question, please mark it as correct.
2016-12-07 4:30 AM
Just to make sure, I uninstalled STM32CubeMX (including configuration, etc) and reinstalled it.
Same behavior.
Thomas.
2017-02-22 8:09 AM
Hello All,
A high CPU usage when enterring in Clock tab, has bee resolved in 4.19.
Could you please test with this version ?
Thanks in advance.
Kind regards
Sirma
2017-02-28 6:28 AM
It didn't resolve the issue moreover often 'clock resolver' gets stucked in a loop where there is no way to cancel 'Searching solution' . Which results in losing work if it wasn't saved before this is extremely annoying issue.
2017-02-28 10:03 AM
Could you share the ioc file of theproject on which you face this issue ?
Kind regards
Sirma
