2016-11-10 7:01 AM
Pin user label disappears when I change the pin function in the cubeMX GUI. This is not an expected behavior, since the already given name of the pin has not changed.
#cubemx2017-12-07 11:35 AM
For ST: Here's the issue. I have a bunch of pins with names that are on ADC1. To do a multi-channel simultaneous conversion, some of these pins are switched over to ADC2. What is the effect? Anybody? Craig Reed? Yes, correct, all of your labels are removed.
There is a quick (relative) way to put them back. If you go into the Configuration/ADC2 widget, under GPIO Settings, you can put the labels back in without a lot of clicking. (yes this works for other subunits, give it a try) But the preferred response would be to NOT scrub the labels.
Andrei
