2024-01-05 11:32 PM
I am facing an issue with the cubeMx UI. After using it for some time about 10 to 15 minutes, the UI is overlapping each other. Then I need to close the UI and start again. Again the issue is present after some time.
CubeMx Version : 6.10.0
2024-01-06 12:59 AM
Hello albinv06,
welcome to the jungle ! I think you are another victim of this well-known very old graphic issue (2018 ?).
You can get some clues here : https://community.st.com/t5/stm32cubemx-mcus/my-cubemx-ui-is-messed-up/td-p/347844/page/2 and there : https://community.st.com/t5/stm32cubemx-mcus/cubemx-ui-is-messed-up-again-again-and-again/td-p/580741/page/5
Good luck !
