2025-12-22
2:00 AM
- last edited on
2025-12-22
5:16 AM
by
Maxime_MARCHETT
My projects are all in C++ and were building completely fine. After I generated the code from CubeMX, the language switched back to C. I had to go and manually switch to C++, then it gave me build errors with linker script... Please fix!
2025-12-22 4:37 AM
Hello @spaceDog16
Actually, this issue has been solved in the latest version of CubeMX 6.16.1, I suggest that you update your version of CubeMX and recheck.
BR, Souhaib
2025-12-22 4:37 AM
Hello @spaceDog16
BR, Souhaib
