2026-04-09 3:07 AM - edited 2026-04-09 3:40 AM
CubeMX Project Manager has a bug, where when I accidentally cleared the "Project Location" field and moved the cursor away CubeMX complains that project location cannot have special characters and cannot be empty. But this popup does not go away and gives you no chance to correct your mistake. Screenshot attached.
Host OS: Ubuntu 24.04.4
CubeMX version: 6.15.0
Edit: Turns out there was a new version of CubeMX (6.17.0) where this problem disappears. You click 4-5 times on OK and the dialog disappears. Should I delete the question in this case?
2026-04-09 3:40 AM - edited 2026-04-09 4:07 AM
Hello @shrinivas96
Let me thank you for posting.
I tested with STM32CubeMX 6.17, and the behavior described is not reproduced by my side.
When I click on OK [ 2 clicks], the pop-up window disappears.
Thanks.
Mahmoud
Hello @shrinivas96
Thanks.
Mahmoud
