2019-05-01 1:55 AM
I'm trying to get DHCP working as an initial step in using LwIP. Have generated project with CubeMX and now I'm catching the problem.
Using Wireshark, I can see that DHCP Discover packet is sent, but no response is received. IT seems that something is wrong with the packet. As a reference, I also captured DHCP packet from my laptop that does work and gets response.
Any advice what is wrong ?
Thanks in advance,
regards,
Rob.
Packet from STM32F439 :
No. Time Source Destination Protocol Length Info
3006 49.570106 0.0.0.0 255.255.255.255 DHCP 350 DHCP Discover - Transaction ID 0x5851f42d
Frame 3006: 350 bytes on wire (2800 bits), 350 bytes captured (2800 bits) on interface 0
Interface id: 0 (\Device\NPF_{A7ACDF3A-ED3E-4FAD-B7B4-533C6D411BF2})
Encapsulation type: Ethernet (1)
Arrival Time: May 1, 2019 10:37:34.873435000 Srednjeevropski poletni �?as
[Time shift for this packet: 0.000000000 seconds]
Epoch Time: 1556699854.873435000 seconds
[Time delta from previous captured frame: 0.075670000 seconds]
[Time delta from previous displayed frame: 11.888756000 seconds]
[Time since reference or first frame: 49.570106000 seconds]
Frame Number: 3006
Frame Length: 350 bytes (2800 bits)
Capture Length: 350 bytes (2800 bits)
[Frame is marked: True]
[Frame is ignored: False]
[Protocols in frame: eth:ethertype:ip:udp:dhcp]
[Coloring Rule Name: UDP]
[Coloring Rule String: udp]
Ethernet II, Src: Stmicroe_00:00:00 (00:80:e1:00:00:00), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Destination: Broadcast (ff:ff:ff:ff:ff:ff)
Source: Stmicroe_00:00:00 (00:80:e1:00:00:00)
Type: IPv4 (0x0800)
Internet Protocol Version 4, Src: 0.0.0.0, Dst: 255.255.255.255
0100 .... = Version: 4
.... 0101 = Header Length: 20 bytes (5)
Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
Total Length: 336
Identification: 0x0001 (1)
Flags: 0x0000
Time to live: 255
Protocol: UDP (17)
Header checksum: 0xba9c [validation disabled]
[Header checksum status: Unverified]
Source: 0.0.0.0
Destination: 255.255.255.255
User Datagram Protocol, Src Port: 68, Dst Port: 67
Source Port: 68
Destination Port: 67
Length: 316
Checksum: 0xf773 [unverified]
[Checksum Status: Unverified]
[Stream index: 8]
[Timestamps]
Dynamic Host Configuration Protocol (Discover)
Message type: Boot Request (1)
Hardware type: Ethernet (0x01)
Hardware address length: 6
Hops: 0
Transaction ID: 0x5851f42d
Seconds elapsed: 0
Bootp flags: 0x0000 (Unicast)
Client IP address: 0.0.0.0
Your (client) IP address: 0.0.0.0
Next server IP address: 0.0.0.0
Relay agent IP address: 0.0.0.0
Client MAC address: Stmicroe_00:00:00 (00:80:e1:00:00:00)
Client hardware address padding: 00000000000000000000
Server host name not given
Boot file name not given
Magic cookie: DHCP
Option: (53) DHCP Message Type (Discover)
Length: 1
DHCP: Discover (1)
Option: (57) Maximum DHCP Message Size
Length: 2
Maximum DHCP Message Size: 1500
Option: (55) Parameter Request List
Length: 3
Parameter Request List Item: (1) Subnet Mask
Parameter Request List Item: (3) Router
Parameter Request List Item: (28) Broadcast Address
Option: (255) End
Option End: 255
Padding: 000000000000000000000000000000000000000000000000…and working DHCP packet from laptop (and DHCP offer it gets as a response) :
280 37.678948 0.0.0.0 255.255.255.255 DHCP 351 DHCP Discover - Transaction ID 0xac96b414
Frame 280: 351 bytes on wire (2808 bits), 351 bytes captured (2808 bits) on interface 0
Arrival Time: May 1, 2019 10:37:22.982277000 Srednjeevropski poletni �?as
Epoch Time: 1556699842.982277000 seconds
[Time delta from previous captured frame: 0.235728000 seconds]
[Time delta from previous displayed frame: 0.000000000 seconds]
[Time since reference or first frame: 37.678948000 seconds]
Frame Number: 280
Frame Length: 351 bytes (2808 bits)
Capture Length: 351 bytes (2808 bits)
Ethernet II, Src: Pegatron_bb:30:10 (0c:54:a5:bb:30:10), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Source: Pegatron_bb:30:10 (0c:54:a5:bb:30:10)
Type: IPv4 (0x0800)
Total Length: 337
Identification: 0x62af (25263)
Flags: 0x0000
Time to live: 128
Protocol: UDP (17)
Header checksum: 0x0000 [validation disabled]
Source: 0.0.0.0
Source Port: 68
Length: 317
Checksum: 0xa8e9 [unverified]
[Stream index: 8]
[Timestamps]
Hops: 0
Transaction ID: 0xac96b414
Seconds elapsed: 0
Client MAC address: Pegatron_bb:30:10 (0c:54:a5:bb:30:10)
Magic cookie: DHCP
Length: 1
DHCP: Discover (1)
Option: (61) Client identifier
Length: 7
Option: (50) Requested IP Address (192.168.0.212)
Length: 4
Requested IP Address: 192.168.0.212
Option: (12) Host Name
Length: 22
Host Name: Robi_Ideapad710_laptop
Option: (60) Vendor class identifier
Length: 8
Vendor class identifier: MSFT 5.0
Length: 14
Parameter Request List Item: (6) Domain Name Server
Parameter Request List Item: (15) Domain Name
Parameter Request List Item: (31) Perform Router Discover
Parameter Request List Item: (33) Static Route
Parameter Request List Item: (43) Vendor-Specific Information
Parameter Request List Item: (44) NetBIOS over TCP/IP Name Server
Parameter Request List Item: (46) NetBIOS over TCP/IP Node Type
Parameter Request List Item: (47) NetBIOS over TCP/IP Scope
Parameter Request List Item: (119) Domain Search
Parameter Request List Item: (121) Classless Static Route
Parameter Request List Item: (249) Private/Classless Static Route (Microsoft)
Parameter Request List Item: (252) Private/Proxy autodiscovery
Option: (255) End
Option End: 255
2019-05-01 2:04 AM
Stupid mistake.
forgot to include MX_LwIP_Process in while loop...
Regards,
Rob.
2019-05-01 2:04 AM
Stupid mistake.
Regards,
Rob.
