2020-03-04 7:01 AM
Hi, I just noticed that since I upgraded from 5.3.0 to 5.6.0 user-labels no longer not get exported as #define's to main.h. This occurs only in following conditions:
* if the 'pin-stacking' option is set AND
* if more than one signal is 'stacked on' (=reserved for) that pin
Pins with only one signal assigned to (whether 'pin-stacking' activated or not) will export normally.
This behavior is new, I didn't have this problem in 5.3.0.
Is it a bug, or am I using the 'pin-stacking' funcion incorrectly?
Best regards, Bernd
2020-04-01 3:33 AM
Hello BerndNW18,
I didn't reproduce the issue, could you please explain more your problem ?
You can share your ioc file in order to check the issue.
Thanks,
Khouloud.
