  • 1756 Views
Resolved! Nucleo-H723ZG: PCLK frequency too high with CubeMX config
Hi all,I am currently using the Nucleo-H723ZG and having difficulties with the clock management using version 1.12.1 of the stm32h7 cubeMx package.The first symptom I encountered was that my USART2 baudrate was three times lower than expected. A few ...
mcozzi by Associate II
  • 2106 Views
STM32CubeMX HAL generated code for STM32F051 faulty
I'm using STM32CubeMX 6.14.1Recently I was added DAC to my project. I doesn't suppose to use DAC with interrupt, I wasn't enable it, but occasionally I was enabled DAC callbacks.Generated the code for Makefile based project.In the end of building pro...
tovis by Associate II
  • 1935 Views
Why STM32CubeMX No More Generating sysmem.c?
Posted on May 26, 2017 at 13:35Hi,How do I enable the STM32CubeMX version 4.21.0 to generate sysmem.c file under startup folder? The file seems to be missing. The older version of STM32CubeMX automatically generates it.#stm32
pohtv by Associate II
  • 4885 Views
Resolved! CubeMX and IAR tool chain
Hi, I’m using STM32CubeMX to configure peripherals and IAR Embedded Workbench for debugging. However, I’ve noticed that whenever I regenerate the code using CubeMX, the application code I previously wrote in IAR gets erased.Is there any setting or co...
curiocity by Associate III
  • 1135 Views
