  • 1757 Views
Does CubeMX code generator has some problems in I2C or not?
Posted on February 19, 2015 at 10:31I'm a beginner in stm32Fx. I'm using Keil IDE and cubeMX code generator.I've used I2C1 and I2C3 in my board with stm32f407 microcontroller and used cubeMX for generating initial codes. I've tried to use I2C3 and i...
hamid by Associate
  • 5543 Views
  • 11 replies
CubeMX pin configuration issue with STM32L152QEHx UFBGA132
Posted on February 23, 2015 at 22:49In attempting to validate a schematic design in progress I used CubeMX to verify that none of the I/O assignments and peripheral functions being called out in the schematic were going to conflict.  I noticed that ...
seth by Associate II
  • 1509 Views
STM32cubeMX in MATLAB Support.
Posted on February 19, 2015 at 05:25I , just installed the updated version of STM32 MAT target 4.0 version in my matlab 2014a . now there is one  block regarding MCU Configuration in which , I have to provide one .ioc file for configuration . My que...
13meep34 by Associate II
  • 1596 Views
STM32CubeMX Bug Report - CAN bus configurator
Posted on March 05, 2015 at 22:55 STM32CubeMX 4.6.0 Configurator for CAN controller has inaccuracy in calculating of time for one bit. If I set the values for CAN speed 500 kbit /s (bit time 2000 ns) then c...
Cube bug or a misunderstanding on my part?
Posted on March 05, 2015 at 01:01My EE was using CubeMX for a 407 and noticed that a lot of the pins can be declared as being GPIO_ANALOG, even if the pins have no analog alternate functions and are not able to be routed to ADCs or DACs.I declared P...
STM32L1 HAL Cube touchkey example
Posted on January 07, 2015 at 20:50I am trying to find an example using a cube to build a project and have a simple touch key. I am only able to find the linear slide example, and non HAL examples. Any help is appreciated! Thank you in advance! #...
travis by Associate
  • 921 Views
CubeMX 4.6 not generate main.c and msp.c
Posted on February 03, 2015 at 12:01When i try to generate basic code for my STM32F429-DISCO board, CubeMX 4.6 software not generate any main.c file sometimes msp.c not be generated too !My toolchain is: Keil MDK5.13 - new updateIs it because my too...
STM32CubeMX support for MCBSTM32F400
Posted on January 28, 2015 at 14:37Does anyone know if there is any planned support for the Keil MCBSTM32F400 within the STM32CubeMX application? #diy #stm32cubemx #mcbstm32f400
USB CDC Device demo on STM32F4 Discovery with STM32CubeMX code?
Posted on October 27, 2014 at 00:34I am trying to get a USB CDC Device demo working on an STM32F4 Discovery board (with the STM32F407) with code from the STM32CubeMX generator application. The process has been murky at best, hopefully one of you can...
nate1 by Associate II
  • 4215 Views
