  • 1756 Views
Hangs in SDIO after update CumeMX
Hello.After updating CubeMX to the latest version, the microSD card is no longer formattedMounting, creating files and writing to them is normal.When calling a function:f_mkfs("", FM_FAT32, 0, work, sizeof work);Hangs up in the HAL_SD_WriteBlocks fun...
RKhal.19 by Associate II
  • 2065 Views
Resolved! Can use cubemx to generate lwip project in stm32h743
Posted on June 30, 2018 at 15:49Hi all:     Now I use stm32h743zi, using cubemx to generate LwIP project, but the LwIP option is gray. Dose anyone know that how to fix this. The following picture is the picture what I confige the cubemx project. Tha...
Yi Zhou by Associate III
  • 2710 Views
Resolved! Any difference between STM32CUBE_MX And Atollic_TrueStudio?
Right at the moment I have 2 software, Atollic TrueStudio & STM32CUBE_MX . I am pretty confused, which one to use for an STM32-Cortex M4 ? Is there any difference between Atollic TrueStudio & STM32CUBE_MX software? Which one is stable? thanks
vmekr by Associate II
  • 2580 Views
STM32CubeMX not running on macOS
After updating the STM32CubeMX Eclipse Plugin to 5.0.0 version I get the following message on running the plugin: "This release of STM32CubeMX Eclipse Plugin cannot be used in macOS".The Plugin still opens, but I can't edit the peripheral values (it'...
flavio23 by Associate III
  • 3575 Views
How to enable external interrupt.
I'm using CubeMX V 5.0.1 to create a simple project for Nucleo-L031K6 board. I've configured PA12 as an input. Under Pinout & Configuration->System Core->NVIC there is no option to enable "EXTI line 4 to 15 interrupts" . Show only enabled interrupts ...
