  • 1756 Views
STM32CubeMX hangs at code generation
I create the project in STM32CubeMX, version 5.1.0.Select STM32F3-Discovery board.Delete USB and change HAL to LLClick "Generate Code" and the program hangs up. the screenshot and .ioc file is attached.How to learn the reason?
DOlov by Associate
  • 1298 Views
STM32CubeMX 5.1.0 eclipse plugin to System regen failure
Using System Workbench 5.8 and 5.9 (both have same issue) with eclipse CubeMX plug in 5.1.0. Target device STM32L462RE. Library is STM32Cube FW_L4 V1.13.0. Initial project and code generation is fine. Launching STLINK-V2 works normally. When ma...
FreeRTOS Tasks stack size on STM32L4
Hi all,I am working on stm32l486 chip.When I created (using CubeMx) two tasks with a stack size equal to 256 words. The project is running well:osThreadDef(Task1, vTask1, osPriorityNormal, 0, 256); Task1Handle = osThreadCreate(osThread(Task1), NULL);...
Dev1 by Associate II
  • 2798 Views
Resolved! CubeMX 5.1.0 can not re-open saved file
I have saved the attached project file in CubeMX, but I can not open it again. CubeMX just waits forever after I start to open it. What can I do? Please give me a hint quicly, I am working on an urgent project. Thanks.
STM32F030C6 MCU Sleep Mode
Hi All,I am working on the STM32F030 MCU and developing code for the low power consumption for my application.I need to develop code for the sleep mode, in which after few minutes it goes to sleep mode to save power. But some how I am not getting tha...
K_P_D by Associate II
  • 3624 Views
Resolved! Why can't a blank CubeMX project not enter while(1) loop.
HiI used a NucleoF072RB and Cube MX. I use Atollic TrueStudio.I wanted to know how to setup and AND before integrating it in another project. So I created a new blank project. I set tup the porject as per the picture ADC_setup. No pin were activate...
sdavi.9 by Associate II
  • 3242 Views
