  • 1756 Views
STM32 Discovery Board Code Generation Problem in STM32CubeMX.
I am actually facing issue in generating the code in STM32CubeMX, seems "STM32Cube FW_F4 V1.24.1" is not available for proper code generation.When I try to download "STM32Cube FW_F4 V1.24.1" I am facing repeated issue. please see the issue screen sho...
HArch by Associate
  • 1593 Views
Error when generating STM32CubeIDE project
Hi!When I tried to generate STM32CubeIde project, an error occurred:searchjar length = /home/juraj/Programy/STM32CubeMX/third_parties_plugins/array = com.st.stm32cube.ide.common.services.mx.jar-0.0.9.jarsearchjar path = /home/juraj/Programy/STM32Cube...
USB Serial firmware example for STM32F303CBT6?
Is there example code for using the Virtual Port Com from CubeMX?(Determine baud, rxchar, txchar [preferably with DMA], CD, etc)I found this: https://damogranlabs.com/2018/02/stm32-usb-cdc/and it looks like a good starting point, but even though I ca...
TJohn.14 by Associate II
  • 1477 Views
USB CDC won't talk to PuTTY
Background: Quick USB stack test on Nucleo F429 with CubeMX-generated USB CDC stack.Added one line to echo input in CDC_Receive_FS (example here: https://damogranlabs.com/2018/02/stm32-usb-cdc/)Windows 10 PC sees virtual COM7 port (usual ding-****, s...
osSignalSet+FreeRTOS Problem
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim){ /* USER CODE BEGIN Callback 0 */  if (htim->Instance == TIM1) {  osSignalSet(defaultTaskHandle, 0x0001); } /* USER CODE END Callback 0 */ if (htim->Instance == TIM4) {  HAL_IncTick(); } /* ...
km naxin by Associate II
  • 1018 Views
