  • 1758 Views
SD card interface code genereated by STM32CUbe32 (5.5.0)
i would request imen to let us know if the STM32CubeMx 5.5.0 is addressing all the issues regarding SD card interface using SDMMC ( 4 bits and DMA). Since the code generated from CubeMX 5.5.0 for nucleo-l476rg BOARD for SD card interface does not wor...
HMaje.1 by Associate III
  • 5815 Views
  • 14 replies
Migration issue from 5.4.0 to 5.5.0
Dear customers, We are facing a little issue during the migration from the 5.4.0 to the 5.5.0 (reported in this thread https://community.st.com/s/question/0D50X0000BxzZV9SQM/upgraded-stm32cubemx-from-540-to-550-and-now-it-fails-to-generate-the-projec...
STM32L452 LSE not running if CSS enabled
I have once activated CSS in CubeMX and then the LSE can no longer be started. Even if I change CSS to disabled in CubeMX and recompile this does not change. I have to say that I have buffered the RTC / LSE with a CAP at VBatt so it does not loose po...
BUG: stm32MXCube ADC prescaler
Hi,There is a bug in the STM32CubeMX when you change the "Clock Prescaler" of the ADC for the STM32G474RE mcu.When i change the value of ADC1, the "Clock Prescaler" values of all the other ADC are also changed to the same value of ADC1.regards
OGhis by Senior
  • 1265 Views
Resolved! I'm trying Tutorial #4 (UART Communication) from CubeMX manual, but it does not work. I'm using a Discovery STM32F334C8T6.
I have followed scrupulously every step, but Tera Term (or other terminal emulators) does not show any sign of communication with my board. The board is a Discovery STM32F334C8T6: the tutorial is tailored to a Nucleo board, but the pinout of the two ...
