  • 1758 Views
Cant Setup Timer Interrupt with HAL and STM32CubeMX.
Im using an STM32L452RE dev. board. and Im trying to set an interrupt once after some time. I have the following subroutines.#define MICROSECOND_TICK_COUNT 80 //clock = 80 MHZ i.e. 1e-6/(1/80e6)=80 TIM_HandleTypeDef myTimer;   void setupTimer(void){ ...
VChav.19 by Associate II
  • 3854 Views
CubeMX - Generated files vs copied files
I'm new to CubeMX and I've read over the documentation a couple of times (speed reading) but can't quite find an answer.My question is what files exactly are generated by the tool and what files are simply copied?Is it the case that all files we find...
Too many ADC interrupt calls added by CubeMX
Hi, I've got some code that uses both ADC1 and ADC3 that I've generated with STM32CubeMX. For both ADCs I want to use interrupts. With this configuration however the CubeMX auto-generated code adds 2 separate calls to the same HAL interrupt handler, ...
DBurr by Senior
  • 2469 Views
