  • 1757 Views
Unable to install CubeL4 version 1.15.1 (patch) in CubeMX
Running CubeMX version 5.6.1 on Win10. No internet connection, so I manually copy the CubeL4 zip files to the PC and then try to install via the "Install/Remove" button under software packages. I have CubeL4 1.15.0 installed. When I check 1.15.1 a...
Bob S by Super User
  • 2930 Views
H743 - SWO not working - PB3 floating
I still struggle with SWO on a custom board with two H743s on it. No matter what I try, SWO pin PB3 is floating. I could get the SWO of a H743 Nucleo board with the hack of clive1 in this post below work a few years ago, but with current firmware/Cub...
CKosa by Associate II
  • 2166 Views
Which CMSIS Version is used with CubeMX? I've updated the CMSIS Version in Cube, but there are still the old CMSIS files copied to the newly generated project files
Is it possibile to choose the CMSIS Version in Cube? What's a good way to manage CMSIS updates? Copy/Paste manually?I'am using Keil µVision 5.29 (Keil Project manually generated -> Reference to copied STM32CubeMX Files).STM32CubeMX 5.6.1Cube MCU Pack...
LHase.1 by Associate II
  • 3599 Views
I am trying to get the STM32F0 TSC touch sensing library working, but for some reason after all my initializing and configurations. I get the TSC interrupt to fire, but my counter's always seem to have the max value. I print out the value with USART.
My code is posted below. Whenever I try to swipe my finger across the touch sensor, nothing seems to be read. However, my TSC interrupt handler is  constantly firing and printing out the value from the TSC counter which for some reason is awlays the ...
RWill.2 by Associate
  • 1570 Views
