  • 1756 Views
Resolved! STM32G071 Push Pull PWM and Fault Pin
Hi,​I​ have control H-bridge with 4 MOSFET up to 100KHz.​Will it possible to Generate PWM in Push Pull Mode with deadtime with STM32G0 MCU and CubeMx ?​Is there any ​PWM Fault pin for that ?​​--Karan ​​​​​
How does any user know initial Ip address of STM chip?
Hi, I kindly need your help. I have a STM32F769 and TCP server application . I am using LWIP stack . In my application server is arm and PC is client. When client tries to send something to arm, arm binds client’s ip address. So the connection is ok ...
nur by Associate II
  • 2375 Views
Resolved! Can't communicate using lwIP other than with ICMP (ping)
Hello,Sorry in advance for my English. I am also very new to embedded systems and softwares worlds.I am currently trying the lwIP TCP/IP stack on a STM32756G-EVAL2 (STM32F756NGH) board. On one end, I have a Red Hat PC with a network interface used sp...
AJOLY.2 by Associate II
  • 7965 Views
GPIOs doing nothing on Nucleo 144 F746
I just got a Nucleo 144 F746. I tried setting up the default configuration in the latest CubeMX for this Nucleo board, and writing a super simple blinky program (put the following in the main while(1) loop:  HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin)...
CKurt.2 by Associate II
  • 2234 Views
