  • 1759 Views
How to use usb hs in stm32f407zgt6 using usb3300?
The usb fs works fine for me, but when I try the usb hs, it gives me error_handler(). I don't know how I have to put it to make it work.My configuration:I use stm32cubeide.I don't know if my configuration is correct respect to pull up and pull down, ...
0693W00000Y7zayQAB.png 0693W00000Y7zbwQAB.png 0693W00000Y7zcaQAB.png 0693W00000Y7zd9QAB.png
IOR.1 by Associate
  • 2176 Views
How to set the desired clock frequency(SCL) for Nucleo-f401RE (Master-Receive- Half Duplex I2S Communication with MEMS Microhone - CUI Device (Slave) ).
Hello , I am using STM Cube IDE for I2S communication between NUCLEO-F401RE and CUI MEMS microphone namely CMM-4030DT-26354-TR . I am current facing a problem to set a clock frequency for SCL pin of Nucleo board. The SCL clock frequency range for ...
smit1 by Associate
  • 3968 Views
I'm trying to generate code for a STM32U558 USB device The USB initialization function MX_USB_Device_Init is empty
STM32CubeMx version 6.7.0STM32Cube_FW_U5_V1.1.1STM32Cube_FW_U5_V1.1.1\Projects\B-U585I-IOT02A\Applications\USBX\Ux_Device_HID_CDC_ACM\Ux_Device_HID_CDC_ACM.iocCopying the ioc file to a new location, double clicking and clicking "generate code" shows ...
Inbara by Associate II
  • 3150 Views
Resolved! How to set PB 8 as BOOT0 pin and PG10 as NRST pin
This is really a basic question, but nevertheless I haven't found an answer.I am confused primarily about visualization of PB8 and PG10 pins inside CubeIDE MX.When I create new project I would expect PB8 and PG10 looking "yellow" and also being defin...
GHrib.1 by Associate III
  • 3609 Views
