  • 1756 Views
Resolved! FMC Clock Mux not found
Hello,Im working on a Project, which i use with it STM32F750N8H6 with external Memory and im trying to interface them to each other.I have so far now done the Configuation of GPIO, TimingParameters..etc but i wanted giving too the Value of the Clock ...
mids400 by Associate III
  • 2453 Views
Fail to upgrade to CubeMX 6.9.0
Hello,I started the upgrade process as always under administrator rights, the download and installation finished successfully and then I need to restart with administrator rights again to fulfil the installation and I get this:I close all the other a...
Egolt.1 by Associate III
  • 2403 Views
sensorless bldc motor controlling issue
I am experiencing issues while trying to operate the BR2804 1700Kv BLDC motor with the IHM07M1 motor controller and either the L476RG or G071RB board. we are just using the software like cube mx , cube ide to genarate code . while using L476RG , all ...
#iR by Associate II
  • 1157 Views
Resolved! difference between _pin and _gpio_port
In cubeMX, Il gave a user name 'led1_rouge' to PI1.When I go to Keil microvision, intellisense gives me two names : led1_rouge_pin led1rouge_gpio_portWhat is the difference between them ?Jean
MJean.3 by Associate III
  • 8346 Views
Adding X-CUBE-NFC6 software to STM32Cube
I wish to run sample code/examples on X-NUCLEO-NFC08A1 and NUCLEO-L476RG development board.Is there any guide describing step by step procedure of adding X-CUBE-NFC6 expansion to STM32CubeMX∕IDE?
Lex by Associate III
  • 941 Views
Resolved! When will STM32CubeMX generate valid device tree for v2.8 TF-A?
Apparently in v2.8 TF-A the RCC device tree block changed significantly for the STM32MP157CAAx board as this commit shows:https://github.com/STMicroelectronics/arm-trusted-firmware/commit/3cf2edd6b87ca5c131108c533761d26cb0539d5eSo old device trees fr...
johnnyc by Associate III
  • 1872 Views
SPI Slave DMA Communication in Trust zone
Hi,we are using a stm32u575zit6q Controller. Having a trust zone enable with dual bank support.our application is to communicate stm32u575zit6q controller to the other MPU with SPI peripheral using DMA.In this case MPU is behave as a SPI master and s...
Ronak by Associate
  • 2158 Views
Resolved! Unknown USB Device on stm32F429ZI device
Hi, Lot of people had this issue, nothing worked for me and I think it might be a newbie mistake. I'm trying to communicate in USB between my PC (host) and a stm32f429ZI board (device). The size of the heap shouldn't be an issue as it seem like the m...
0693W00000QM3BUQA1.png 0693W00000QM38fQAD.png 0693W00000QM3CDQA1.png 0693W00000QM3CcQAL.png
Lucas213 by Associate II
  • 3633 Views
