2025-05-09
9:56 PM
- last edited on
2025-05-12
3:11 AM
by
Lina_DABASINSKA
Dear STMicroelectronics Support Team,
I am working on the STM32F407G-DISC1 (STM32F4 Discovery) board and I am unable to watch printf() statement in SWV ITM Console output in STM32CubeIDE.
To enable the SWO trace output, I referred to the user manual and identified that SB12 (SWO) was in OFF state by default. Following the recommendation, I removed the 0-ohm resistor between the SB12 pads on the backside of the board and directly shorted the pads using solder to connect the SWO signal to PB3.
I also attached an image of the soldered SB12 pads for your reference.
Here are the board details:
- **MCU Model**: STM32F407VGT6
- **Board**: STM32F4 Discovery
Could you please advise if any additional configuration or hardware action is needed for the SWO functionality to work properly?
Request you to send me a reference video link for any modifications mentioned by you.
Thank you for your support.
Best regards,
Vakati Hemanth ,
2025-05-20 3:10 AM
Hi @vakati ,
Please refer to the first section of the article: Using the ITM console for printf redirects and LWIP debug messages.
Another option: How to redirect the printf function to a UART for debug messages.
-Amel
2025-05-20 5:46 AM
Test ITM_SendChar by itself.
Clock and core settings must be consistent. ie what the MCU is running at and what you tell the PC side software
