2023-10-24 2:54 AM
I have a project for a STM32H7. The idea is to split the project into two separate projects. This is a functional separation. Can anyone help me what elementary steps are necessary to make these projects as follows:
One project should land directly in the flash, the other project will be loaded from an external flash into the ram via a bootloader(which exists!). Now both projects must still be functional.
I am aware that I must create appropriate headers, so that necessary functions must create that appropriate interfaces know each other. However, I have no idea how I have to adjust the linkerfile etc..
2023-10-24 6:39 AM
Here you can find helping hands for your project: https://www.fiverr.com/categories/programming-tech/electronics-engineering/embedded-systems-iot
