2025-04-01 1:32 PM
Does anyone know if there is a stack analyzer tool / plugin available in CubeIDE, in particular to analyze the stacks dynamically allocated in ThreadX Memory pools?
Also, under ThreadX Thread List, there is a "stack usage" column. This column is always blank (or N/A), is there something that needs to be done to enable the "stack usage"?
2026-02-20 7:24 AM
Same. I would sure love if someone from this huge company could answer this. ST? Hello?
2026-02-20 7:39 AM
In the User Manual:
Also, as CubeIDE is Eclipse, you could try searching for general Eclipse-based stuff...
2026-02-21 1:40 AM - last edited on 2026-02-21 1:46 AM by Andrew Neil
You can enable the stack view with the "Hamburger" button:
