2021-04-16 2:55 AM
2021-04-16 3:24 AM
Hello!
I would suggest creating a new workspace in the version of CubeIDE you want to use. Copy the project to that workspace and then launch CubeIDE and go to File -> Import... -> General -> Existing projects into workspace.
Let me know if anything is unclear of if it doesn't work the way you hoped it would!
2021-04-16 3:58 AM
Hi Markus ,. Thank you . You use the term " new workspace" . I an not sure what you mean . Do you man a new project ? How do you create a "New Workspace " There need to be detailed information added to "Help " to address this topic .
2021-04-16 4:24 AM
Hi Markus .
I think this is what you mean
Note you will ned to locate there the STM 32 Cube IDE workspace folder is on the disk . This where it is in my case . C:\Users\user\STM32CubeIDE\workspace_1.6.0
Is it correct?
2021-04-16 7:03 AM
Hi Markus
The .ioc file is not renamed when the project is imported . It still has the original projects name . I guess I need to close STM 32 IDE CUBE and change the .ioc file name in the project folder on the disk to have the same name as the new project . ST really need to address this issue . Please add a DETAILED STEP BY STEP procedure how to clone /copy projects basically . This is a use case for a lot of users I expect .
