2021-07-05 8:17 AM
Hey all,
I'm trying to verify register values in my project, as per this link: https://www.freertos.org/Debugging-Hard-Faults-On-Cortex-M-Microcontrollers.html
I'm attempting to open the break point window in the debugger, and manually define an execution or access break point at that address, but having difficulties in creating a break point at an address.
If someone could guide me on how to do so, that would be much appreciated!
Cheers :)
2021-07-05 8:35 AM
I believe you are talking about data breakpoints, afaik these are called "watchpoints" in Eclipse and are separately listed from program breakpoints.
Also, if you want to watch an address without having an explicit variable sitting on that address in C, in gdb, you'd dereference the address
(gdb) watch *0x20000000
Hardware watchpoint 1: *0x20000000I don't use the eclipsoids but I'd guess this might be similar.
2021-07-05 8:35 AM
2021-07-05 8:50 AM
Looks like that's exactly what I'm looking for, thanks!
Found this useful link to help others who might stumble past: https://mcuoneclipse.com/2012/04/29/watchpoints-data-breakpoints-in-mcu10/
