2024-10-21 12:20 PM
My aim is to be able to get shorter line for compiled file.
How to tell the makefile generator of *.mk files to print to console my version of message.
What I mean is, instead of verbose format:
---- Console ---------------------------------------------
19:58:32 **** Incremental Build of configuration dbg
make -j8 all
arm-none-eabi-gcc "../Drivers/dev_debug/retarget.c" -mcpu=cortex-m7 -std=gnu11 -g3 -DPCB_ISSUE_NUMBER=2 ... etc.
arm-none-eabi-gcc "../Drivers/dev_debug/abd.c" -mcpu=cortex-m7 -std=gnu11 -g3 -DPCB_ISSUE_NUMBER=2 ... etc.
arm-none-eabi-gcc "../Drivers/dev_debug/dddd.cpp" -mcpu=cortex-m7 -std=gnu11 -g3 -DPCB_ISSUE_NUMBER=2 ... etc.I would like to see this:
make -j8 all
compiling retarget.c
compiling abd.c
compiling dddd.cpp
etc.I know how this is done in Makefile, just how to tell autogenerator to do that ? Where is a template the generator uses ?
# excerpt from *.mk file
# Each subdirectory must supply rules for building sources it contributes
Drivers/dev_debug/%.o Drivers/dev_debug/%.su Drivers/dev_debug/%.cyclo: ../Drivers/dev_debug/%.c Drivers/dev_debug/subdir.mk
@echo "compiling $<"
@arm-none-eabi-gcc "$<" -mcpu=cortex-m7 -std=gnu11 -g3 -DPCB_ISSUE_NUMBER=2 .. /many other options/ .. -mfloat-abi=hard -mthumb -o "$@"Thank you
Ferro
