2025-04-04 2:59 AM
Hi, I am programming touchgfx and having problems configuring the configurations to use external memory but now I get these errors, how to fix it?
E:/STM32/IDE/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.13.3.rel1.win32_1.0.0.202411081344/tools/bin/../lib/gcc/arm-none-eabi/13.3.1/../../../../arm-none-eabi/bin/ld.exe: Gateway_LCD_Test_CM7.elf section `ExtFlashSection' will not fit in region `FLASH'
E:/STM32/IDE/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.13.3.rel1. win32_1.0.0.202411081344/tools/bin/../lib/gcc/arm-none-eabi/13.3.1/../../../../arm-none-eabi/bin/ld.exe: Gateway_LCD_Test_CM7.elf section `TouchGFX_Framebuffer' will not fit in region `RAM_D1'
E:/STM32/IDE/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.13.3.rel1. win32_1.0.0.202411081344/tools/bin/../lib/gcc/arm-none-eabi/13.3.1/../../../../arm-none-eabi/bin/ld.exe: region `RAM_D1' overflowed by 1989208 bytes
E:/STM32/IDE/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.13.3.rel1.win32_1.0.0.202411081344/tools/bin/../lib/gcc/arm-none-eabi/13.3.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 3183456 bytes.
I hope everyone can help, thank you very much !!!
2025-04-18 3:18 AM
Hello @NguyenAnhHieu_ ;
Which STM32 are you using?
Could you please share the LinkerScript?
I recommend you to look at this post may help you.
Thank you.
Kaouthar
