2021-12-08 11:57 PM
In my live expression, I see my unsigned variables go negative values. For example, when uint8_t type variable is 128 it shows as a -1, if 129 then -2. I don't understand what is wrong. I can see uint8_t in the type column in the live expression. It happens with every unsigned variable 16 or 32 does not matter.
Does anybody know anything about it?
Best Regards.
2023-04-08 10:44 AM
Did you got the proper justification, if yes can you please explain it.
Thank you
2023-04-08 11:02 AM
> it shows as a -1
it - who shows in which state ? in debug ? in -> memory view ? explain detail, + example.
