2022-12-02 10:41 AM
I get an error like this when I first compile any project, regardless of controller and code. This error occurs after the project is successfully compiled. If there is an error in the code, this error does not occur because the compilation is not finished. If I compile again after this error occurs, the error does not appear again. This error has been present for over 2 years but it does no harm. I have no idea why. This error occurs even if I do a clean install. I am using Windows 10 with Turkish language. I got the same error on another computer(w10 turkish).
What do you think could be the reason?
