2025-05-12 4:09 PM - edited 2025-05-12 4:29 PM
This IDE has gone into some crazy mode where each window maximizes itself on the screen/. I've tried clicking every single maximize/minimize/restore button, closeing the app, restarting the computer.....
This worked and suddenly broke.
Is there some way to make this thing reset back to it's default state?
2025-05-12 4:32 PM
Another screen
2025-05-13 2:41 AM
Have you tried resetting the perspective (Menu item - Window / Perspective / Reset Perspective...)?
2025-05-14 4:24 AM - edited 2025-05-14 6:15 AM
Hello @sgordon777
Could you please provide more details about the STM32CubeIDE version that you are using and your OS.
As mentioned by @CTapp.1 :Go to Window in the menu bar. Select Reset Perspective. This will reset the layout to its default configuration and if the issue persists try switching to a new workspace: Go to File > Switch Workspace > Other...
THX
Ghofrane
2025-05-14 5:44 AM
Double clicking in free area on top of window doesnt restore it ?
here ->
2025-05-14 6:34 AM - edited 2025-05-14 6:36 AM
That's worth a try - it does normally. If it doesn't, it's worth trying to reset the perspective.
2025-05-14 8:39 PM
This did it, thanks
2025-05-14 8:41 PM
No, it didn't for me. Thats the first things I tried since I know that double clicking this border area can decouble windows.
I fixed it with "reset perspective" option above
2025-05-14 9:12 PM - edited 2025-05-14 9:12 PM
CTRL+M = Maximizie active View or EditorThe root-cause is as you said probably a double-click on a border area or using CTRL+M.
You can of course do a "perspective reset". But an easier fix (less impact on your perspective tweaks) is to hit CTRL+M again to untoggle maxmimization.
