2020-02-24 12:14 PM
I'm trying to learn some coding and STM32, and have been using STM32CubeIDE for some days now.
But today it did an upgrade, and after that I can't download (or debug) my code.
I have tried both OpenOCD and GDB-server.
In OpenOCD it says:
"Failed to execute MI command:
target remote localhost:3333".
And in ST-LINK GDB server I get the error below:
target remote localhost:61234".
Both filas at around 89% (almost no SW in it, only toggling the LED).
During this download phase, the SWD-LED is toggling between red and green (like it's downloading/communication).
I have STM32 ST-LINK Utility installed as well, and there I can connect to the board.
Any ideas on what in the update, that could have done this?
(I can also mention that I'm a newbe on this, so I guess it's a quite simple solution).
2020-02-24 1:04 PM
Just found a log over it, maybe that could be to some help:
!ENTRY org.eclipse.cdt.dsf.gdb 4 5012 2020-02-24 21:52:41.102
!MESSAGE Error in final launch sequence:
Error message from debugger back end:
localhost:3333: The system tried to join a drive to a directory on a joined drive.
!STACK 1
org.eclipse.core.runtime.CoreException: Failed to execute MI command:
at org.eclipse.cdt.dsf.concurrent.Query.get(Query.java:112)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launchDebugSession(GdbLaunchDelegate.java:242)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launchDebugger(GdbLaunchDelegate.java:106)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launch(GdbLaunchDelegate.java:94)
at com.st.stm32cube.ide.mcu.debug.launch.DSFDelegate.launch(DSFDelegate.java:285)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:860)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:719)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1017)
at org.eclipse.debug.internal.ui.DebugUIPlugin$2.run(DebugUIPlugin.java:1220)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: java.lang.Exception: localhost:3333: The system tried to join a drive to a directory on a joined drive.
at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxThread.processMIOutput(AbstractMIControl.java:993)
at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxThread.run(AbstractMIControl.java:822)
!SUBENTRY 1 org.eclipse.cdt.dsf.gdb 4 10004 2020-02-24 21:52:41.102
!MESSAGE Failed to execute MI command:
!STACK 0
2020-02-24 1:08 PM
For newbie stuff where things actually work relatively painlessly out-of-the box, consider using KEIL, ST has a free license for CM0(+) devices.
