STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
How to attach debugger to an already running MCU ?
Hi,I'm using STM32CubeIDE with a SEGGER J-Link connected to an STM32F7.I manage to flash and debug the board but I can't find how to attach the debugger to the target without resetting it.Thank you for your help.HG
HGate.2 by Associate
  • 1671 Views
Unavailable "Setting" tab and problem with make
Hi everybody!Have problem with building project, which is OK in TrueStudio. I have:Core/Inc/font24.o:(.rodata.Font24_Table+0x0): first defined herecollect2: error: ld returned 1 exit statusmake: *** [makefile:42: test3.elf] Error 1"make -j7 all" term...
EVoro.1 by Associate
  • 1777 Views
Resolved! STM32CubeIDE Project setup issue
When trying to create a Debugger configuration for a project opened from sources + Makefile, STM32CubeIDE fails to create the configuration and shows the following error messages:" Not able to get board target."" An internal error has occurred. Updat...
Romain1 by Associate III
  • 3675 Views
Azure expansion hsm emulator
I'm working with a STM32F4 Discovery (413) eval board and working through bringing the device up on Azure IoT hub through various mechanisms. I've successfully (the firmware does not like being talked to from a Mac serial port, i've only had succes...
SBade.1 by Associate II
  • 754 Views
How to fix STM32CubeIDE very small on 4k display?
I would like to log this bug that concerns STM32CubeIDE.The CubeMX handles the scaling well, why not the IDE?https://community.st.com/s/question/0D50X0000BMGpgySQD/how-to-fix-stm32cubeide-very-small-on-4k-display
  • 868 Views
How to use ITM Printf inside a Console of STM32CubeIDE
Hello,I would like to use the ITM Printf directly inside a Console of STM32CubeIDE but It doesn't work on my side.I was able to display a character inside a "SWC ITM data Console" by using ITM_SendChar(). But I have the next issues:- For using printf...
Fabien B by Associate III
  • 4863 Views
Can i write polynomial equation in STM32cubeIDE
Hello,I am trying to estimate initial SOC of battery by using a polynomial equation obtained from discharged voltage data of battery. I successfully run this polynomial equation in MATLAB but don't know how to write in STM32cubeIDE.The obtained polyn...
Mohan1 by Associate III
  • 1718 Views
