STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
CubeIDE debugger fails to load the binary - SOLVED
To end the horrible winter night... even the debugger fails in CubeIDE under Windows.On the same Windows machine CubeIDE can debug the same target in a Linux VM.Isn't it curious?Same error with OpenOCD and ST-LINK GDB server. Of course, Atollic just ...
Pavel A. by Super User
  • 2476 Views
CubeIDE cannot import Atollic project (details)
So I'm now trying to import Atollic project into CubeIDE.Started from this: Then entered path of the source projectThe project is in subdirectory PROJ_ATOLLIC so I've unchecked the upper item.(Does it really think that the project is SW4STM?? Hmmm) C...
0693W000007Yz6GQAS.png 0693W000007Yz6LQAS.png 0693W000007Yz6QQAS.png 0693W000007Yz6VQAS.png
  • 2213 Views
CubeIDE permanently deletes all projects
CubeIDE 1.5.1CubeMX 6.1.1Just got all the projects + files in a folder permanently deleted by CubeIDE when creating a new project.Permanently meaning that the files didn't go to the bin.What happened is that, using CubeIDE, I tried to create a new pr...
Resolved! Anyone know how to resolve a "fail to get required stm32cube firmware package" error when importing a new project?
I tried importing a project using STM32CubeIDE V1.4 and got the following error: I tried doing package updates and everything I could think of but I wasn't able to figure out how to resolve this (tried googling/forum searching it but no luck). Anywa...
JBee.1 by Associate II
  • 9089 Views
  • 10 replies
Thumbs2 instruction set only ?
When you go the Tool Settings tab in the Project Properties you are only able to select Thumb2 for the instruction set.Is it intended or is there a "hidden" way to switch to the ARM instruction set ?
JLABO.1 by Associate II
  • 3162 Views
Resolved! Colors in CubeIDe
How to change background color of the elements that I have selected but later removed that selection in dark theme? If I select CDC_Receive_FS, for example, and it is green in dark theme, after I continue to do anything the background of all instance...
EL314 by Associate III
  • 5711 Views
