STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
LSM6DS example and dev. board.
Hello, does anybody know what example and development board to use for LSM6DS for air mouse development?And is LSM6DS the best sensor to use?
GS2 by Senior II
  • 932 Views
Resolved! Rename the project does not rename the .ic file
I wanted to use the ioc and all the code from a project into another project. So, I copied the project and pasted in a workspace, then renamed the project, but ioc is not changed. So while opening, I get error messageInvalid Input: Must be project's ...
Techn by Senior III
  • 2381 Views
STM32CubeIDE BUG with working CMake project
Hello,I have a working project based on CMake.I tried to build it under STM32CubeIDE with no success.Here is the output when trying to build the project:**** CMake Configure of configuration config_default for project CMakeProject **** C:\Work\Projet...
ANauz.1 by Senior II
  • 1715 Views
STUSB1602 + STM32F446ZE
I am currently working on a project where USB-C PD stack implementation on STM32F446ZE board. I have downloaded the necessary files which I have shown in my attachment (zip folder downloaded from https://github.com/usb-c/STUSB1602). Kindly answer my ...
Disassembly view buggy?
This is using Stm32CubeIDE  Version: 1.14.0 Build: 19471_20231121_1200 (UTC)When I hit a breakpoint that says "view disassembly" that button often goes to a blank disassembly view. Same if you try and go to a particular address.  If you close the cur...
musmuris by Associate II
  • 4410 Views
Unavailable FW package issue (fixed)
Dear STM32CubeMX/STM32CubeIDE users We detected an issue linked to unavailability of some Cube packages for multiple STM32 series. This misbehavior is caused by an issue in the published database used by our tools. The issue is currently under invest...
Resolved! STCubeIDE Missing Required Packages
Good morning,I have recently upgraded CUBEIDE to v1.15.1I tried to add a example project to my workspace and it states Required Software Package STM32Cube_FW_WB_1.20.0When I click next and finish, I get the error I have checked for updates etc and tr...
POliv_0-1718782299870.png POliv_1-1718782344766.png POliv_2-1718782475462.png
POliv by Associate III
  • 2012 Views
